| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Check NET MGT Port Status LEDs
Check Power Supply Status LEDs
Display Faulty Components (fault_state)
Display Faulty Components (/SP/faultmgmt)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Display the General Alarm State of Systems and Components
Oracle ILOM Target Alarm States
Display Oracle ILOM Sensor Status
Determine Oracle ILOM Sensor Target Types
Evaluating a Voltage Sensor Alarm
Evaluating a Temperature Sensor Alarm
Evaluating a Speed Sensor Alarm
Evaluating a State Sensor Alarm
Evaluating a Presence Sensor Alarm
Presence Sensor Alarm Conditions
Access the Oracle ILOM CLI (NET MGT Port)
Exit the Restricted Linux Shell
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
-> show /SYS/Fabric_Mgmt NOTE: show on Fabric_Mgmt will launch a restricted Linux shell. User can execute switch diagnosis, SM Configuration and IB monitoring commands in the shell. To view the list of commands, use "help" at rsh prompt. Use exit command at rsh prompt to revert back to ILOM shell. FabMan@gateway_name->
The restricted shell prompt (FabMan@gateway_name->) is displayed, and you can now issue hardware and InfiniBand commands.
When you want to leave the restricted shell, type the exit command.
