| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Check NET MGT Port Status LEDs
Check Power Supply Status LEDs
Display Faulty Components (fault_state)
Display Faulty Components (/SP/faultmgmt)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Display the General Alarm State of Systems and Components
Oracle ILOM Target Alarm States
Display Oracle ILOM Sensor Status
Determine Oracle ILOM Sensor Target Types
Evaluating a Voltage Sensor Alarm
Evaluating a Temperature Sensor Alarm
Evaluating a Speed Sensor Alarm
Evaluating a State Sensor Alarm
Evaluating a Presence Sensor Alarm
Presence Sensor Alarm Conditions
Access the Oracle ILOM CLI (NET MGT Port)
Enter the Restricted Linux Shell
Exit the Restricted Linux Shell
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Temperatures within the chassis are regulated by the fans. For the fan cooling to be effective, the intake room air temperature must be below 25°C.
When a temperature is too high, it can be caused by:
Air flow is insufficient – The fan speeds are too slow, the fans have stopped spinning, or the fan is missing altogether.
Cooling air temperature is too high – No component can be cooled to a temperature lower than the cooling medium itself. Additionally, as the cooling air temperature increases, the air's ability to remove heat diminishes.
Heat generated within a component is greater than that removed – The cooling system was designed for a certain power dissipated by the components. When those components experience high computing or throughput loads, or are subjected to overvoltage situations when a voltage regulator fails, they generate more heat.
For example, if the temperature at sensor target /SYS/MB/T_I4A is too high, then the fans speeds (/SYS/FANx/TACH) are collectively too low, the cooling air temperature (/SYS/MB/T_FRONT) is too high, the voltage powering the I4 switch chip (/SYS/MB/V_I41.2V) is too high, or the loading on the switch chip is too high.
When a temperature is too low, it is rarely a detrimental situation. There is an exception, when the temperature of a component is the same as room temperature or lower, there is a great possibility that the component is not functioning as expected.
For example, if the temperature at sensor target /SYS/MB/T_I4A is too low, as compared to the cooling air temperature (/SYS/MB/T_FRONT), then the I4 switch chip is being held in a state of reset, the voltage for the I4 switch chip (/SYS/MB/V_I41.2V) is not being provided, or the I4 switch chip has catastrophically failed.
Note - The gateway is not fitted with an air filter. Therefore, contaminants can enter the gateway and adhere to cooling surfaces. The effect is two-fold, the contaminants prevent the flow of cooling air to the components, and the contaminants behave as insulators, retaining waste heat dissipated by the components. If supplied voltages, cooling air temperatures, and fans speeds are within acceptable values, yet component temperatures are high, the extent of contamination is severe.
When temperatures are out of range, the suggested action is to check the fans and replace any that are not operating properly. See Servicing Fans. If new fans do not resolve the problem, then replace the gateway.
