Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Subnet Manager's Location History
Display the Secret M_Key Configuration
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
If you want to quickly determine the master Subnet Manager's state, the getmaster command provides the LID and GUID of the InfiniBand device hosting the master Subnet Manager.
FabMan@gateway_name->getmaster Local SM enabled and running, state MASTER 20120831 09:45:17 Master SubnetManager on sm lid 1 sm guid 0x3ba01234567a0a0 : SUN DCS 36P QDR mnm2 10.172.144.66 FabMan@gateway_name->
