| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Subnet Manager's Location History
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
You can display the active (currently in use) or modified (pending) secret M_Key configuration with the smsubnetprotection list state command.
Note - You must be in a configuration session to display the modified configuration.
FabMan@gateway_name->smsubnetprotection list state
where state is either active or modified. For example:
FabMan@gateway_name->smsubnetprotection list modified # File_format_version_number 1 # Sun DCS IB mkey config file # This file is generated, do not edit # secretmkey=enabled # nodeid=o4nm2-gw-6 # time=15 Sep 04:03:00 # checksum=0 #! commit_number : 4 Mkey Untrusted Mkey Smkey Attribute ------------------ ------------------ ------------------ --------- 0x00abcdefabcdef01 0x1aa45124fee612ae 0x15fc26aea300f831 0x00abcdefabcdef02 0x4ccd8230de6cd348 0x3fc7e6ad701a8a2a 0x00abcdefabcdef03 0x9baa1debcc74de5e 0x1b253003600d137b C FabMan@gateway_name->
In the output, the Attribute heading identifies:
C – The current secret M_Key
S – The standby secret M_Key (if any)
Gateway Reference, smsubnetprotection command
