Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Switch Chip Port to QSFP Connector Mapping
Locate a InfiniBand Device and Connector From the GUID and Port
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
In some situations, you might need to know the status of each route through the gateway. Additionally, the listlinkup command displays where InfiniBand cables are connected to the gateway.
FabMan@gateway_name->listlinkup connected Connector 2A Present <-> Switch Port 24 up (Enabled) Connector 3A Present <-> Switch Port 26 up (Enabled) Connector 6A Present <-> Switch Port 35 up (Enabled) Connector 8A Present <-> Switch Port 31 up (Enabled) Connector 11A Present <-> Switch Port 12 down (Enabled) Connector 13A Present <-> Switch Port 9 down (Enabled) Connector 14A Present <-> Switch Port 7 down (Enabled) Connector 0A-ETH Present Bridge-0 Port 0A-ETH-1 (Bridge-0-2) up (Enabled) Bridge-0 Port 0A-ETH-2 (Bridge-0-2) up (Enabled) Bridge-0 Port 0A-ETH-3 (Bridge-0-1) up (Enabled) Bridge-0 Port 0A-ETH-4 (Bridge-0-1) up (Enabled) Connector 1A-ETH Present Bridge-1 Port 1A-ETH-1 (Bridge-1-2) up (Enabled) Bridge-1 Port 1A-ETH-2 (Bridge-1-2) up (Enabled) Bridge-1 Port 1A-ETH-3 (Bridge-1-1) up (Enabled) Bridge-1 Port 1A-ETH-4 (Bridge-1-1) up (Enabled) Connector 9B Present <-> Switch Port 13 up (Enabled) FabMan@gateway_name->
If connector and its link have been autodisabled, the listlinkup command will append the connector status with (AutomaticHighErrorRate), (AutomaticBadSpeedOrWidth), or both. For example:
Connector 0A Present<-> Switch Port 20 down (AutomaticHighErrorRate)
In this situation, check the condition of the connector and cable. Refer to Gateway Service, servicing cables.
Gateway Reference, listlinkup command
