| Skip Navigation Links | |
| Exit Print View | |
			Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Switch Chip Port to QSFP Connector Mapping
Locate a InfiniBand Device and Connector From the GUID and Port
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
On occasion, you might need to turn off a port. For example, a cable might become damaged and cause symbol errors that affect the switch chip's performance. Use the disableswitchport command to disable a switch chip port and its respective cable connection.
Note - The disableswitchport command is persistent and survives reboots.
FabMan@gateway_name->disableswitchport [--reason=reason] Switch port
where:
reason is the reason for disabling the port, Blacklist or Partition.
port is the number of the port (1 to 36).
Alternatively, type.
FabMan@gateway_name->disableswitchport [--reason=reason] connector
where connector is the number of the QSFP connector (0A to 15B).
For example:
FabMan@gateway_name->disableswitchport Switch 14 Disable Switch port 14 Initial PortInfo: # Port info: DR path slid 65535; dlid 65535; 0 port 14 LinkState:.......................Active PhysLinkState:...................LinkUp LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................10.0 Gbps After PortInfo set: # Port info: DR path slid 65535; dlid 65535; 0 port 14 LinkState:.......................Down PhysLinkState:...................Disabled FabMan@gateway_name->
Gateway Reference, disableswitchport command
