Oracle ILOM Legacy Targets for Voltage
This table lists voltage sensors. An out-of-range value might indicate a faulted
component. See Oracle ILOM Legacy Target Replaceable Components or Faulted Item Replaceable Components for a
link to the service task for that component.
Line voltage into PS 0
/SYS/PS0/V_IN
100 to 252 volts
Power source or power cord
Line voltage into PS 1
/SYS/PS1/V_IN
100 to 252 volts
RTC backup battery
/SYS/MB/V_VBAT
> 2.548 volts
Battery
Standby voltage
/SYS/PS_3V3
2.944 to 3.685 volts
Power supplies
Supplied voltage out of PS 0
/SYS/PS0/V_OUT
10 to 14 volts
Power supply 0
Supplied voltage out of PS 1
/SYS/PS1/V_OUT
10 to 14 volts
Power supply 1
