Power On the Switch
Connect the power cords to power on the switch.
Determine your first step:
If you serviced a component that did not require you to power off the
server, continue to Verify the Serviced Component.
If you replaced the switch itself, or if you have removed the power
cords for another reason, continue to the next step.
Lower the retaining wire in front of the rear power receptacles.
See Rear Panel Components for the
location of the power receptacles.
Install the power cords in the rear power receptacles.
Note -
Installing either power cord will power on the switch.
Ensure that you the power cords are installed securely.
Lift the retaining wire to secure the power cords to the switch.
At the front of the switch, verify the power supply LEDs.
For a description of these LEDs, see Power Supply LEDs.
The AC LED lights green to indicate that the power supplies are
connected to facility power.
A moment later, the OK LED lights green to indicate the power supplies
are at full power.
If you replaced a power supply as part of a service operation, verify that the
power supply Attention LED is not on.
If the Attention LED is on, see Verify a Power Supply, then
return to this procedure.
If the Attention LED is off, continue to the next step.
Continue to Verify the Serviced Component.continue to Verify the Serviced Component.
