Verify a Data Cable
After you install a data cable, you can verify its functionality.
Verify that the data cable is no longer considered faulty.
See Locate a Faulty Data Cable,
then return to this task.
If the known good replacement data cable is still identified as faulty, check
the cable's connection remote from the switch.
See Detecting and Managing Faults for
assistance.
If you are verifying the data cable as part of another task, return to that
task.
