Go to main content
Oracle® Fabric Interconnect F2-12 Service Manual
Exit Print View
Updated: November 2016
Open Problem Faults
In the output of the /System/Open_Problems target, the string of text that begins with fault.chassis. identifies the faulty component. Additionally, the text that follows Resource is the Oracle ILOM target of the component that faulted. This table provides example output for various component faults. Once you identify the component that has faulted, see Oracle ILOM Legacy Target Replaceable Components and Faulted Item Replaceable Components for links to service tasks.
Component Faulted
/System/Open_Problems Output
Ambient temperature
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:11:35 2015 System MB (Motherboard) fault.chassis.env.temp.over-fail (Probability:100, UUID:4c4bdfa1-f7d5-c7a7-e59e-f9a8ce4fab21, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
Battery
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:00:01 2015 System MB (Motherboard) fault.chassis.battery.fail (Probability:100, UUID:76a2179a-51bd-c836-a7f1-af62953577fa, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
Fan module
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:18:44 2015 System FMx (Fan Module) fault.chassis.device.fan.fail (Probability:100, UUID:0ebf1655-8700-c90e-fa53-ea6c3b2b25a0, Resource:/SYS/FMx, Part Number:N/A, Serial Number:N/A, Reference Document:http://support.oracle.com/msg/---)
Main board temperature
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:04:16 2015 System MB (Motherboard) fault.chassis.temp.shutdown (Probability:50, UUID:01bacc0f-986e-e346-94aa-84e41a1c1595, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
Main board voltage
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:13:26 2015 System SP (Service Processor) fault.chassis.voltage.fail (Probability:100, UUID:0a408985-6011-ccd7-c3a1-e01c7254ea87, Resource:/SYS/SP, Part Number:7096151, Serial Number:BS9089M+15306P00M0, Reference Document:http://support.oracle.com/msg/---)
Power supply
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:17:11 2015 Power PSx (Power Supply 1) fault.chassis.device.psu.fail (Probability:100, UUID:b516a939-23c2-ee8b-e997-d915ca03d044, Resource:/SYS/PSx, Part Number:7065505-01, Serial Number:BS2517, Reference Document:http://support.oracle.com/msg/---)
Related Information
