If you require technical support for your switch, you will be asked to provide the chassis serial number. You can read the chassis serial number from a RFID tag located on the front of the switch, to the left of the fan modules. See Switch Front Components the location of the serial number.
If it is not convenient to read the strip or the RFID tag, you can use Oracle ILOM to obtain the chassis serial number.
See Accessing the SP.
-> show /SYS product_serial_number /SYS Properties: product_serial_number = 1133BDN082 ->
