You must determine which data cable is faulty before you replace it.
For each cable connected to a known functional host, the Link LED should be on. See and RJ-45 Link LEDs.
See Remove a Data Cable.
See Accessing the SP.
-> start /System/Networking/Switches/Switch_0/fs_cli Are you sure you want to start /System/Networking/Switches/Switch_0/fs_cli (y/n)? y Management Switch for Oracle Fabric Interconnect F2-12 SEFOS login:
SEFOS login: root Password: password SEFOS#
The default password is admin123.
SEFOS# show interfaces status Port Status Duplex Speed Negotiation Capability ---- ------ ------ ----- ----------- ---------- Gi0/1 not connected Half - Auto Auto-MDIX on Gi0/2 connected Full 1 Gbps Auto Auto-MDIX on Gi0/3 connected Full 1 Gbps Auto Auto-MDIX on Gi0/4 not connected Half - Auto Auto-MDIX on Gi0/5 not connected Half - Auto Auto-MDIX on Gi0/6 connected Full 1 Gbps Auto Auto-MDIX on Gi0/7 not connected Half - Auto Auto-MDIX on ... Gi0/13 connected Full 1 Gbps Auto Auto-MDIX on ... Gi0/23 not connected Half - Auto Auto-MDIX on Gi0/23 connected Full 1 Gbps Auto Auto-MDIX on Gi0/25 connected Full 1 Gbps Auto Auto-MDIX on Gi0/26 connected Full 1 Gbps Auto Auto-MDIX on Ex0/1 not connected Full 10 Gbps No-Negotiation Auto-MDIX on Ex0/2 not connected Full 10 Gbps No-Negotiation Auto-MDIX on SEFOS#
In the output, Port is the port as seen on the rear panel. Ports Gi0/25 and Gi0/26 are internal to the switch architecture. Ports Ex0/1 and Ex0/2 are the two SFP+ uplink ports. The Status is the state of the port. The Duplex, Speed, and Negotiation are the parameters of the link. The Capability indicates if auto-crossover capability is on.
SEFOS# exit Connection closed by foreign host Entering character mode Escape character is '^]'. start: The session with /System/Networking/Switches/Switch_0/fs_cli has ended. ->
-> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y Serial console started. To stop, type ESC (
[user@hostname ~]#
where:
user is the current username.
hostname is the host name of the SCP.
[user@hostname ~]# su admin Welcome to IBOS Controller Copyright (c) 2012-2015 Oracle Corp. All rights reserved. Enter "help" for information on available commands. Enter the command "show system copyright" for licensing information admin@hostname[OFOS]
If this is the first time OFOS is accessed, the OFOS configuration wizard might start. If this happens, refer to Run the Oracle Fabric OS Configuration Wizard in Oracle Fabric Interconnect F2-12 Installation Guide.
[OFOS] show ioports name type state descr v-resources ------------------------------------------------------------------------------ 0/1 gwEthernet10GbPort up/indeterminate 0 0/2 gwEthernet10GbPort up/indeterminate 0 0/3 gwEthernet10GbPort up/indeterminate 0 0/4 gwEthernet10GbPort up/indeterminate 0 0/5 gwEthernet10GbPort up/indeterminate 0 0/6 gwEthernet10GbPort up/indeterminate 0 0/7 gwEthernet10GbPort up/indeterminate 0 0/8 gwEthernet10GbPort up/indeterminate 0 8 records displayed [OFOS]
In the output, the name is the port number as seen on the rear panel. The state is of the local port/peer port. The descr is the node descriptor of the peer port. The v-resources are the number of VLANs and VNICs supported on that port.
[OFOS] show infiniband-port name state mode_state guid ------------------------------------------------------------------------------ 0/1 up/down switching 0 0/2 up/down switching 0 0/3 up/down switching 0 0/4 up/down switching 0 . . . 0/27 up/down switching 0 0/28 up/down switching 0 0/29 up/down switching 0 0/30 up/down switching 0 30 records displayed [OFOS]
In the output, the name is the port number as seen on the rear panel. The state is of the local port/peer port. The mode_state is the condition of the link. The guid is the GUID of the peer port.
Type exit and press the Enter key, then press the Esc key and type (.
[OFOS] exit [root@nsn156-168 ~]# Serial console stopped. ->
