Remove a Data Cable
Removing a single data cable is a hot-swap
operation. If you are removing all data cables as part of a switch replacement, the
switch must be powered off.
This task describes how to remove the
cables from the switch, so that the cable can be replaced. Whenever possible, label
each end of the cable with the port number and location. If you are removing all
cables for switch replacement, start removing the cables from the left side of the
switch, working your way to the right.
Note -
These instructions are valid for both IB and Ethernet data cables.
Determine which data cable to remove.
See Locate a Faulty Data Cable.
Consider your next step.
Locate the cable to be removed.
(Optional) If necessary, label that cable so that its corresponding port, its
peer, or both, are identified.
Consider your next steps.
If you are removing all cables for switch replacement, start with the PrizmMT
cables.
If you are removing a PrizmMT cable, go to Step 6.
If you are removing an assembled fiber optic QSFP cable, go to Step 7.
If you are removing an LC cable, go to Step 8.
If you are removing an RJ-45 cable, go to Step 9.
Remove a PrizmMT cable.
Pinch the PrizmMT cable connector housing between your thumb and
forefinger.
The housing is either magenta or black colored.
From the chassis.
With a steady force, pull the PrizmMT connector straight out of the
receptacle.
Insert a filler plug into the receptacle.
Go to Step 10.
Remove an assembled fiber optic QSFP cable.
Grasp the release collar on the MTP connector and pull back.
The LC connector and fiber optic cable come free of the transceiver.
Release the latch on the QSFP transceiver and pull on the latch to
remove the transceiver.
The transceiver comes free.
Set the transceiver aside.
Go to Step 10.
Remove an LC cable.
Press the release tab on the LC connector and pull back.
transceiver.
Go to Step 10.
Remove an RJ-45 cable.
Pinch the tab and opposite side of the RJ-45 connector between your
thumb and forefinger.
Use either your thumb or forefinger to depress the release tab.
From the Oracle F2 Quad Port 10GBASE-T module.
Pull the RJ-45 connector straight out of the receptacle.
Carefully move the cable out of the cable management comb.
Cap the end of the cable if possible.
Repeat Step 3 to
Step 11 for any additional
cables to be removed.
