You can use the Locate LED to pinpoint the location of a switch. This task is helpful when you need to identify one particular switch from many other rack components.
See Accessing the SP.
-> set /SYS/LOCATE value=Fast_Blink
The white Locate LED blinks.
-> set /SYS/LOCATE value=off
