Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Acquire the BXOFED Software (Linux)
Install the BXOFED Software (Linux)
Acquire the ConnectX-2 Firmware
Creating VNICs Under Gateway Manual Mode (Linux)
Gateway Manual Mode Overview (Linux)
Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux)
Determine VLAN Associations for Gateway Manual Mode (Linux)
Configure and Create VNICs for Gateway Manual Mode (Linux)
VNIC Configuration on Linux Hosts in Gateway Manual Mode
Creating VNICs Under Host Manual Mode (Linux)
Host Manual Mode Overview (Linux)
Central Configuration File (Linux)
VNIC-Specific Configuration File (Linux)
Determine VNIC Configuration Parameters for Host Manual Mode (Linux)
Create the Central Configuration File (Linux)
Create the VNIC-Specific Configuration Files (Linux)
mlx4_vnic_confd Daemon (Linux)
Configure and Create VNICs for Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Ethernet Over InfiniBand Overview (Oracle Solaris)
Verify That the Ethernet Over InfiniBand Driver Is Installed (Oracle Solaris)
Install the Ethernet Over InfiniBand Driver (Oracle Solaris)
Configure IP Addresses on the Data Link (Oracle Solaris)
Create Oracle Solaris VNICs With VLAN Tagging (Oracle Solaris)
Display Gateway Ethernet Port Information
Display Gateway Port Information
Display the Gateway Instance Number
Display Information About the Gateway
Add or Delete Connectors From a LAG
VNIC Allocation on the Gateway
Controlling Gateway Ports and Parameters
Enable a Gateway Ethernet Port
Disable a Gateway Ethernet Port
Set the Gateway Ethernet Port Parameters
Set the Gateway Instance Number
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
When you create a VLAN, you create a mapping between a gateway connector, a VLAN identifier, and a partition key. You can create VLANs with the createvlan command. If a VNIC will be associated to a VLAN, you must create the VLAN before the VNIC.
Note - Due to hardware limitations for MultiCast groups, there is a maximum of 1000 VLANs.
Note - Regardless if you plan to use VLANs, you must configure a no VLAN to P_Key relationship. For example, the VLAN ID, NO, is assigned to the P_Key, default.
Note - The association of VLAN identifier NO to partition key default survives firmware upgrades.
See Determine VLAN Associations for Gateway Manual Mode (Linux).
FabMan@gateway_name->createvlan connector|lagname -vlan vlan_ID -pkey p_key
where:
connector is the name of the connector (0A-ETH-1 to 0A-ETH-4, 0A-ETH, 1A-ETH-1 to 1A-ETH-4, and 1A-ETH). This value is column one of the gateway MAC address list.
lagname is the identifier of the LAG.
vlan_ID is the VLAN identifier (NO or 2 to 4094). This value is column four of the gateway MAC address list.
Note - Do not use VLAN identifiers 0, 1, or 4095. According to the IEEE 802.1Q specification, VLAN ID 0 is used for priority tag, and VLAN ID 1 is usually reserved for a switch or bridge management VLAN.
p_key is the partition identifier (1 to 7fff or default). This value is column five of the gateway MAC address list.
For example, to associate connector 1A-ETH-3 with VLAN 3 and default partition key:
FabMan@gateway_name->createvlan 1A-ETH-3 -vlan 3 -pkey default FabMan@gateway_name->
Note - For the createvlan command, given a connector|lagname and vlan_id combination, there is only one p_key permitted.
FabMan@gateway_name->showvlan Connector/LAG VLN PKEY ------------- --- ---- 0A-ETH-1 0 ffff 0A-ETH-2 0 ffff 0A-ETH-3 0 ffff 0A-ETH-4 0 ffff 1A-ETH-1 3 ffff 1A-ETH-1 0 ffff 1A-ETH-2 3 ffff 1A-ETH-2 0 ffff 1A-ETH-3 3 ffff 1A-ETH-3 0 ffff 1A-ETH-4 3 ffff 1A-ETH-4 0 ffff FabMan@gateway_name->
Gateway Reference, createvlan command
Gateway Reference, showvlan command
