Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Acquire the BXOFED Software (Linux)
Install the BXOFED Software (Linux)
Acquire the ConnectX-2 Firmware
Creating VNICs Under Gateway Manual Mode (Linux)
Gateway Manual Mode Overview (Linux)
Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux)
Determine VLAN Associations for Gateway Manual Mode (Linux)
Configure and Create VNICs for Gateway Manual Mode (Linux)
VNIC Configuration on Linux Hosts in Gateway Manual Mode
Creating VNICs Under Host Manual Mode (Linux)
Host Manual Mode Overview (Linux)
Central Configuration File (Linux)
VNIC-Specific Configuration File (Linux)
Determine VNIC Configuration Parameters for Host Manual Mode (Linux)
Create the Central Configuration File (Linux)
Create the VNIC-Specific Configuration Files (Linux)
mlx4_vnic_confd Daemon (Linux)
Configure and Create VNICs for Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Ethernet Over InfiniBand Overview (Oracle Solaris)
Verify That the Ethernet Over InfiniBand Driver Is Installed (Oracle Solaris)
Install the Ethernet Over InfiniBand Driver (Oracle Solaris)
Configure IP Addresses on the Data Link (Oracle Solaris)
Create Oracle Solaris VNICs With VLAN Tagging (Oracle Solaris)
Display Gateway Ethernet Port Information
Display Gateway Port Information
Display the Gateway Instance Number
Display Information About the Gateway
Add or Delete Connectors From a LAG
VNIC Allocation on the Gateway
Controlling Gateway Ports and Parameters
Enable a Gateway Ethernet Port
Disable a Gateway Ethernet Port
Set the Gateway Ethernet Port Parameters
Set the Gateway Instance Number
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
You must create VLANs before VNICs.All VNICs are assigned to a VLAN, even if the VLAN ID is NO. For consistency, you can assign the VLAN ID of NO to the P_Key of default.
See Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux).
See Create VLANs.
See Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux) or Determine VLAN Associations for Gateway Manual Mode (Linux).
FabMan@gateway_name->createvnic connector|lagname <-guid guid>|<-host hostname -port port>|<-node string -port port> -mac mac -vlan vlan_ID -pkey p_key
where:
connector is the name of the connector (0A-ETH-1 to 0A-ETH-4, 0A-ETH, 1A-ETH-1 to 1A-ETH-4, and 1A-ETH). This value is column one of the gateway MAC address list.
lagname is the identifier of the LAG.
guid is the global unique identifier of the target port on the host associated with the VNIC. This value is column two of the gateway MAC address list.
hostname is the host name of the management controller or system name recognized by the BridgeX manager.
port is the port of the host.
string is the character string in the node description field.
mac is the machine address code. This value is column three of the gateway MAC address list.
Note - Only even numbers are supported for the most significant byte of the MAC address (unicast).
Note - If you do not assign a MAC address, the VNIC is not utilized. You must later assign a MAC address to the VNIC with the modifyvnic command if you want to use the VNIC.
vlan_ID is the VLAN identifier. This value is column four of the gateway MAC address list.
p_key is the partition identifier (default). This value is column five of the gateway MAC address list.
For example, to create a persistent VNIC for connector 1A-ETH-3 associated with VLAN 3 with partition key default, type.
FabMan@gateway_name->createvnic 1A-ETH-3 -guid 00:03:BA:00:01:00:E3:71 -mac 02:02:02:02:02:01 -vlan 3 -pkey default FabMan@gateway_name->
Note - If the VNIC is to be non-persistent, append the -n option to the command line.
Note - For VNICs created by the createvnic command, the Network Interface names at the host which is set by the DEVICE parameter in the ifcfg-ethX (where X is identifier), the name should be different from eth0 to eth7, since these names are reserved for devices created and controlled from the host. A suggested name scheme would be ethgateway_instance_VNIC_ID, but all names apart for eth0 to eth7 would be valid.
FabMan@gateway_name->showvnics ID STATE FLG IOA_GUID NODE IID MAC VLN PKEY GW --- -------- --- ----------------------- ---------- ---- ----------------- --- ---- -------- 16 UP N 00:21:28:00:01:3E:CE:A0 mnm34-55 0000 02:02:02:02:02:04 3 ffff 1A-ETH-4 13 UP N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:01 3 ffff 1A-ETH-3 15 UP N 00:21:28:00:01:3E:CE:9F mnm34-55 0000 02:02:02:02:02:03 3 ffff 1A-ETH-1 14 UP N 00:03:BA:00:01:00:E3:72 mnm34-60 0000 02:02:02:02:02:02 3 ffff 1A-ETH-2 FabMan@gateway_name->
Gateway Reference, createvnic command
Gateway Reference, showvnics command
