Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Acquire the BXOFED Software (Linux)
Install the BXOFED Software (Linux)
Acquire the ConnectX-2 Firmware
Creating VNICs Under Gateway Manual Mode (Linux)
Gateway Manual Mode Overview (Linux)
Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux)
Determine VLAN Associations for Gateway Manual Mode (Linux)
Configure and Create VNICs for Gateway Manual Mode (Linux)
VNIC Configuration on Linux Hosts in Gateway Manual Mode
Creating VNICs Under Host Manual Mode (Linux)
Host Manual Mode Overview (Linux)
Central Configuration File (Linux)
VNIC-Specific Configuration File (Linux)
Determine VNIC Configuration Parameters for Host Manual Mode (Linux)
Create the Central Configuration File (Linux)
Create the VNIC-Specific Configuration Files (Linux)
mlx4_vnic_confd Daemon (Linux)
Configure and Create VNICs for Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Ethernet Over InfiniBand Overview (Oracle Solaris)
Verify That the Ethernet Over InfiniBand Driver Is Installed (Oracle Solaris)
Install the Ethernet Over InfiniBand Driver (Oracle Solaris)
Configure IP Addresses on the Data Link (Oracle Solaris)
Create Oracle Solaris VNICs With VLAN Tagging (Oracle Solaris)
Display Gateway Ethernet Port Information
Display Gateway Port Information
Display the Gateway Instance Number
Display Information About the Gateway
Add or Delete Connectors From a LAG
Controlling Gateway Ports and Parameters
Enable a Gateway Ethernet Port
Disable a Gateway Ethernet Port
Set the Gateway Ethernet Port Parameters
Set the Gateway Instance Number
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
By default, VNICs are created and allocated by the management controller of the gateway using Gateway Manual Mode. The createvnic command creates the VNICs, and the resulting VNIC resources are controlled by the gateway.
Alternatively, individual hosts can create and allocate VNICs on the gateway. There are two ways to enable this functionality.
sethostvniclimit – Running the sethostvniclimit command on the management controller of the gateway restricts the number of VNICs that can be created by specified host ports, for specified external ports 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4. Using the sethostvniclimit command to allow host created VNICs is optimal, because the VNIC resources are controlled by the gateway.
allowhostconfig – Running the allowhostconfig command on the management controller of the gateway allows all hosts connected to the gateway through the InfiniBand fabric to create unlimited VNICs on any external port (0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4). In this situation, VNIC resources are not controlled by the gateway. Use of the allowhostconfig command requires consideration of the impact on the gateway's performance.
Only one of these methods can be used at a time. You can display which method is available for use with the showgwconfig command. If in the output of the showgwconfig command the Running Value for the Allow host VNIC config parameter is yes, then unlimited host created VNICs functionality is enabled (allowhostconfig). If you want to restrict host created VNICs, use the disallowhostconfig command to change the Running Value to no (as seen with the showgwconfig command), and then use the sethostvniclimit command.
Gateway Reference, sethostvniclimit command
Gateway Reference, allowhostconfig command
Gateway Reference, showgwconfig command
Gateway Reference, disallowhostconfig command
