Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Install a Processor Module or Processor Filler Module
  1. Determine your first step.
    • If you are replacing the cover as part of the upgrade process, or if you are servicing a processor module, go to Step 2.
    • If you are installing new processor modules as part of the upgrade process, go to Step 4.
  2. Place the cover back onto the processor module, and slide the cover forward until the latch clicks into place.
    image:Graphic showing how to install the processor module cover.
  3. Determine your next step.
    • If you are installing a new processor module, upgrading the memory, or replacing a faulty DIMM, go to Step 4.
    • If you are replacing the covers on the new processor modules to upgrade the server, return to Server Upgrade Process.
  4. Open the latches on the processor module or processor filler module, and insert the module into the empty processor module slot in the server.
    image:Graphic showing how to install the processor module or processor filler module.
  5. Push the levers together toward the center of the processor module or processor filler module, and press the levers firmly against the module to fully seat the module back into the server.
    The levers should click into place when the module is fully seated in the server.
    image:Graphic showing how to lock the handles.
  6. Determine your next step.
  7. Determine your next step.
Related Information
