Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Verify the PCIe Card
  1. Ensure that you have completed the following:
  2. Verify that the Fault LED is not lit on the PCIe card.
  3. Verify that the System Service Required LEDs on the front panel and rear I/O module are not lit.
    See Interpreting LEDs.
  4. Verify that the System PCIe Fault LED on the front panel is not lit.
    See Front Panel Controls and LEDs.
  5. Perform one of the following tasks based on your verification results:
  6. Verify that the green Power LED is lit on the card that you installed.
  7. Log in to Oracle ILOM.
    See Log In to Oracle ILOM (Service).
  8. Start the faultmgmt shell.
    -> start SP/faultmgmt/shell
    Are you sure you want to start the faultmgmt shell (y/n)? y
    faultmgmtsp>
  9. Use the fmadm faulty command to determine if the server is operating normally.
    • If a fault was detected, see Diagnostics Process.
    • If no fault was detected, the PCIe card was installed successfully.
  10. At the Oracle Solaris prompt, ensure that the card is enabled.
    # hotplug list -l | grep PCIE
    Example:
    /pci@300/pci@1/pci@0/pci@6 [PCIE1] EMPTY
    /pci@340/pci@1/pci@0/pci@6 [PCIE3] ENABLED
    /pci@380/pci@1/pci@0/pci@a [PCIE9] EMPTY
    /pci@3c0/pci@1/pci@0/pci@e [PCIE11] EMPTY
    /pci@400/pci@1/pci@0/pci@c [PCIE2] EMPTY
    /pci@440/pci@1/pci@0/pci@c [PCIE4] EMPTY
    /pci@480/pci@1/pci@0/pci@4 [PCIE10] EMPTY
    /pci@4c0/pci@1/pci@0/pci@8 [PCIE12] EMPTY
    /pci@500/pci@1/pci@0/pci@e [PCIE5] EMPTY
    /pci@540/pci@1/pci@0/pci@e [PCIE7] ENABLED
    /pci@580/pci@1/pci@0/pci@a [PCIE13] EMPTY
    /pci@5c0/pci@1/pci@0/pci@8 [PCIE15] EMPTY
    /pci@600/pci@1/pci@0/pci@8 [PCIE6] EMPTY
    /pci@640/pci@1/pci@0/pci@8 [PCIE8] EMPTY
    /pci@680/pci@1/pci@0/pci@4 [PCIE14] EMPTY
    /pci@6c0/pci@1/pci@0/pci@4 [PCIE16] EMPTY
Related Information
