See Front Panel Controls and LEDs or Rear Panel Controls and LEDs.
If the SP LED is lit, see Diagnostics Process.
See Interpreting LEDs.
If the Service Required LED is lit, see Diagnostics Process.
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no fault was detected, the SP was installed successfully.
-> show /SP/clock /SP/clock Targets: Properties datetime = Tue Jan 01 23:15:59 1970 timezone = GMT (GMT) uptime = 0 days, 00:01:18 usentpserver = disabled Commands: cd set show ->
-> set /SP/clock datetime=MMDDhhmmYYYY
-> set /SP/clock timezones=3_to_4_characters
where the timezone value equals a three or four character timezone abbreviation, such as EST or AHST.
