Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Remove the Rear Chassis Subassembly
The rear chassis subassembly is a cold-service component that can be replaced only by qualified service personnel. For its location, see Rear Panel Components (Service).
Caution
Caution  -  This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause server components to fail.
Caution
Caution  - Do not attempt to remove the rear chassis subassembly while the server is in the rack. You must remove the chassis to service the rear chassis subassembly.
  1. Power down the server.
    See Removing Power From the Server.
  2. Disconnect the power coards.
    See Disconnect the Power Cords.
  3. Take the necessary ESD precautions.
    See Prevent ESD Damage.
  4. At the front of the server, remove all of these components:
    Component
    Link
    Cables
    Ensure that you label the cables.
    Processor modules (top to bottom)
    Main module
    Power supplies
  5. At the rear of the server, remove all of these components.
    Component
    Link
    Cables
    Ensure that you lable the cables.
    Fan modules
    PCIe carriers
    Rear I/O module
    Caution
    Caution  - Do not attempt to remove the chassis alone without the aide of another person or a mechanical lift.
  6. Determine your next step:
    • If you have another person to assist you, go to Step 8.
    • If you are alone, go to Step 7.
  7. Place a mechanical lift under the chassis, and remove the screws that fasten it to the rack.
    image:Graphic showing how to remove the chassis.
  8. Remove the chassis from the rack, and place it on an appropriate surface.
  9. Using a Phillips screwdriver, loosen the five screws that secure the rear chassis subassembly to the server chassis, and then, slide the rear chassis subassembly out and away from the chassis.
    image:Graphic showing how to remove the rear chassis subassembly screws and rear chassis subassembly..
  10. Slide the rear chassis subassembly out and away from the chassis.
Related Information
