Exit Print View
See Connect the Power Cords.
See Power On the Server (Oracle ILOM).
See Log In to Oracle ILOM (Service).
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no fault was detected, the front I/O assembly was installed successfully.
Remove the Front I/O Assembly
Install the Front I/O Assembly
