Exit Print View
See Connect the Power Cords.
See Power On the Server (Oracle ILOM).
See Log In to Oracle ILOM (Service).
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no fault was detected, the rear chassis subassembly was installed successfully.
Determine if the Rear Chassis Subassembly Is Faulty
Install the Rear Chassis Subassembly
