Remove a Power Supply
The power supplies are hot-service components
that can be replaced at any time. For the location of the power
supplies, see Front Panel Components (Service).
| Caution -
This procedure requires that you handle components that are sensitive to
electrostatic discharge. This discharge can cause server components to
fail.
- Locate
the power supply in the server that you want to remove.
- Go to the rear of the server
and locate the AC power connector at the rear of the server that
supplies power to the faulty power supply.
- Disconnect that power cord.
- At the front of the server, squeeze
the release latches together on the power supply to be removed,
then pull the extraction lever toward you to disengage the power
supply.
- Pull the power supply out of
the server.
- Install the replacement power
supply.
See Install a Power Supply.
