The rear I/O module is a cold-service component that can be replaced only after you have powered off the server. For the location of the rear I/O module, see Rear I/O Module Port Locations.
Caution - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause server components to fail. |
See Prevent ESD Damage.
See Rear Panel Components (Service) for the location of the rear I/O module in the server.
You will reconnect the cables to the same ports on the replacement rear I/O module.
