- Verify that the power supply Power OK and AC Present LEDs are lit and that the Fault LED is
not lit.
See Rear Panel Controls and LEDs.
- Verify that the front and rear
Service Required LEDs are not lit.
See Interpreting LEDs.
- Log in to Oracle ILOM.
See Log In to Oracle ILOM (Service).
- Start the faultmgmt shell.
-> start SP/faultmgmt/shell
Are you sure you want to start the faultmgmt shell (y/n)? y
faultmgmtsp>
- Use the fmadm faulty command
to determine if the server is operating normally.
If a fault was detected,
see Diagnostics Process.
If no fault was detected, the power supply was installed
successfully.
