Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
PCIe Carrier LEDs and Controls
image:Illustration that shows the LEDs and buttons on the PCIe carrier.
No.
LED
Icon
Description
1
CAR
PCIe carrier.
2
Attention Required button
ATTN
Indicates an operational fault. You can also press this button to alert the server to a newly installed PCIe card.
3
Power OK LED(green)
image:Icon for the Power OK LED
Indicates these conditions:
  • Off – PCIe card is not running. You can safely remove the card or install a new card.
  • Steady on – PCIe card is powered on and is running in its normal operating state. No service actions are required. You cannot remove the PCIe card.
  • Blinking – PCIe card is powering up or powering down. You cannot insert or remove the card.
4
Service Required LED (amber
image:Icon for the Service Required LED
The Service Required LED indicates these conditions:
  • Off – PCIe card is operating normally.
  • On – PCIe card requires service.
