Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Determine Which Fan Module Is Faulty
The following LEDs are lit when a fan module fault is detected:
  • System Service Required LEDs on the front panel and rear I/O module
  • Server Fan Fail LED on the rear I/O module
  • Service Required LED on the faulty fan module
  1. Determine if the System Service Required LEDs are lit on the front panel.
    See Interpreting LEDs.
  2. Determine if the Server Fan Fail LED on the front panel is lit.
    See Front Panel Controls and LEDs.
  3. From the rear of the server, check the fan module LEDs to identify which fan module needs to be replaced.
    See Fan Module LED.
  4. Remove the faulty fan module.
    See Remove a Fan Module.
Related Information
