To send a network test from the IP and gateway addresses configured in Oracle ILOM to a device on the network, follow this procedure:
To issue a ping connectivity test from the CLI, type one of the following:
set /SP|CMM/network/test ping=device_ipv4_address_on network
set /SP|CMM/network/test ping6=device_ipv6_address_on network
If the test failed, an error message appears. On some Oracle servers a succeed message appears if the test succeeded.
To issue a ping connectivity test from the web, do the following:
