Oracle ILOM provides a set of configurable properties that help you to manage the BIOS configuration parameters on an Oracle ILOM managed x86 server. These configurable Oracle ILOM properties enable you to:
Back up a copy of the configuration parameters in the BIOS non-volatile data store.
Restore a copy of the backed-up configuration parameters to the BIOS non-volatile data store.
Reset the parameters in the BIOS non-volatile data store to factory defaults.
In addition, Oracle ILOM dynamically monitors the parameters in the BIOS non-volatile data store to ensure that they are in sync with the parameters in the Oracle ILOM BIOS Configuration file. A configuration sync status, appearing in the CLI and web interface, indicates the current state of the BIOS parameters stored in the Oracle ILOM BIOS Configuration file.
