System BIOS Version
(system_bios_version=)
Read-only
The system BIOS Version
property identifies the version of the BIOS firmware that is currently
installed on the managed Oracle x86 server.
Boot Mode
(boot_mode=)
Read-only
Legacy|UEFI
The BIOS Boot Mode property
indicates that the system boots in one of the following modes:
To adjust the BIOS boot mode, refer to the adminstration guide
for your system.
BIOS Configuration: Sync Status
(config_sync_status=)
Read-only
OK|Reboot Required|
Internal Error
Note -
As of firmware 3.2.4, the BIOS Sync Status property is not
available on all Oracle x86 servers.
The BIOS Configuration Sync
Status property indicates one of the following states:
OK – The
BIOS configuration parameters maintained by Oracle ILOM are in-sync with
the configuration parameters in the BIOS non-volatile data store.
Reboot Required – The
BIOS configuration parameters maintained by Oracle ILOM are out-of-sync
with the configuration parameters in the BIOS non-volatile data
store. The Oracle x86 server must be rebooted to sync the BIOS parameters.
Internal Error – Oracle
ILOM is unable to read the BIOS non-volatile data store and is prevented
from initiating a BIOS Backup or Restore operation. For further assistance,
contact Oracle Service.
BIOS Configuration: Reset
To Defaults
(reset_to_defaults=)
Read|Write
Factory |None
The Reset To Defaults property
provides one of the following values:
Factory – Sets
to factory defaults.
None – This
value (None) appears after resetting the parameters in the BIOS non-volatile
data store to factory defaults.
BIOS Configuration: Backup
(dump_uri=)
Write-only
The BIOS Configuration Backup
property enables you to create a copy of the parameters in the BIOS
non-volatile data store and save those parameters to a BIOS Configuration
file in the ILOM file system.
BIOS Configuration: Restore Status
(restore_status=)
Read-only
OK |
Restore pending |
Partial restore: invalid configuration entry |
Partial restore: invalid boot order entry |
Partial restore: invalid configuration and boot order entries
Note -
As for firmware 3.2.4, the Restore Status property is not
The BIOS Configuration Restore
OK – The
last Restore operation succeeded for restoring the Oracle ILOM BIOS
configuration parameters to the host BIOS non-volatile data store.
Restore pending – The
Restore operation is pending a host power off.
Note – The Restore
operation is performed by Oracle ILOM when the host server is powered
off.
configuration entry – The last Restore operation
failed to restore one or more of the host BIOS configuration parameters.
boot order entry – The last Restore operation
failed to restore one or more boot devices in the host boot order
list.
configuration and boot order entries – The last
Restore operation failed to restore one or more BIOS configuration
parameters and one or more boot devices in the host boot order list.
(load_uri=
restore_options)
Read|Write
All|
Configuration only|
Bootlist only | Cancel Restore
property enables you to restore the BIOS parameters previously saved
by Oracle ILOM to the host BIOS non-volatile data store. The options
for restoring the BIOS parameters include:
All – Restores
all BIOS configuration parameters that were previously saved by
Oracle ILOM.
Configuration only – Restores
the previously saved setup parameters.
Bootlist only – Restores
the host boot list parameters previously saved by Oracle ILOM.
Cancel Restore (or action=cancel) – Cancels
the initiated Restore operation.
Note -
The Cancel Restore option in the web interface is only
available if: (1) you initiated a Restore operation, and (2) the host
operating system on the managed Oracle x86 server has not yet been
powered down or reset.
Note -
As of firmware 3.2.4, the Cancel Restore option is not
supported on all Oracle x86 servers.
Transfer Method Options
Read|Write
Browser | TFTP| FTP |SFTP |SCP |HTTP
|HTTPS
When importing or exporting the Oracle ILOM
BIOS configuration parameters, you can specify one of the following
transfer methods:
Browser – Web
interface option only. This option enables you to specify the location
of the file.
TFTP – This
option enables you to specify the TFTP host IP address or name and
the directory path to the file.
FTP – This
option enables you to specify the host IP address or name, user
name and password for the FTP server, as well as the directory path
to the file location.
SFTP – This
option enables you to specify the host IP address or name, username
and password for the SFTP server, as well as the directory path
SCP – This
option enables you to specify the host network address, user name
and password for the SCP server, as well as the directory path to
the file location.
HTTP – This
option enables you to specify the host network address, username
and password for the HTTP server, as well as the directory path
HTTPS – This
option enables you to specify the host network IP address or name,
user name and password for the HTTPS server, as well as the directory path
