Configure Local Client KVMS
Settings
Before You Begin
Administrator (a)
role privileges must be enabled in Oracle ILOM to modify the KVM
State property.
Console (c) role privileges must
be enabled in Oracle ILOM to modify the Host Lock Settings.
The property for Mouse Mode is configurable in Oracle
ILOM as of firmware release 3.2.2 or later.
Note -
For servers running Oracle ILOM firmware version 3.2.1, Oracle ILOM automatically sets the
applicable mouse mode based on the host server's hardware configuration.
- To
access the server SP KVMS settings in Oracle ILOM, do the following:
- Web – Click
Remote Console > KVMS > KVMS Settings.
- CLI – Type:
show /SP/services/kvms
- Modify the following KVMS properties
as required:
State
(servicestate=) |
Enabled |
The KVMS service State is
enabled by default for redirection.
This State property must be enabled for you to use the Oracle
ILOM Remote System Console Plus. If you disable the State property,
you will not be able to use the Oracle ILOM Remote System Console
Plus.
CLI Syntax for KVMS Service State:
set /SP/services/kvms servicestate=enabled|disabled |
Maximum Session Count
(max_session_count=) |
4 |
4 (default)
|3|2|1
The Maximum Session Count property enables you to control the number of users permitted to
view video redirection sessions that are launched from the server SP. The Maximum Session Count
property is available in Oracle ILOM as of firmware release 3.2.4.
Mouse Mode
(mousemode=) |
Absolute |
Absolute |Relative
As of Oracle ILOM firmware version 3.2.2, the Mouse Mode property
in Oracle ILOM is set to Absolute by default.
Absolute mode is recommended for all host servers running
Windows, Oracle Solaris, or a version of Linux that includes a driver
that supports Absolute Mouse Mode. Use Relative Mouse Mode if the
remote host is running a version of Linux that does not include
a mouse driver that supports Absolute Mouse Mode.
Note - If the mouse mode is modified when a primary user has
a remote system console session opened on the SP, the change does
not take affect until the primary session user either: 1) uses the
KVMS menu in the session window to Relinquish Full-Control of the
session and to Take Full-Control of the session; or, 2) exits and
relaunches the session window. Taking these actions to change the
mouse mode on the client, will cause any active storage redirection
session on the SP to stop.
CLI Syntax for Mouse Mode
set /SP/services/kvms mousemode=absolute|relative |
Host Lock Mode
(lockmode=) |
Disabled |
- To apply your modifications,
click Save on the KVMS Settings page.
