Setting
SPARC Host TPM State
Oracle ILOM provides a set of Oracle Solaris TPM properties that enable system administrators
to manage the state of the Trusted Platform Module (TPM) feature on the host SPARC
server. The TPM property is configurable from the Oracle ILOM CLI or web interface. For
further details about TPM configurable property values, see the following tables.
Note - TPM properties for x86 servers are managed in the BIOS
Utility. For further details about x86 operating system TPM properties
and requirements, refer to the Oracle x86 server administration
guide.
Table 76 TPM Property Values for Host SPARC Servers
TPM
(mode=)
(forceclear=) |
Disabled ('off') |
Mode = activated | deactivated | off (default);
Forceclear= false (default) | true
Mode – Set one of the following:
Activated – Enables the TPM state on the
SPARC server at the next host power-on event.
Deactivated – Disables the TMP state on the
Off – Ignores the TPM chip on the SPARC
server.
Forceclear – To clear the TPM device data on the
SPARC server at the next host power-on event, set the
property for Forceclear to 'true' and set the property for
Mode to 'Activated'.
Note -
The Forceclear property is automatically set to 'false' after
CLI Syntax to Set TPM
Properties:
For a single-server SP, type:
set /HOST/tpm
mode=[off|deactivated|activated]
forceclear=false|true
For a multi-domain server SP, type:
set
/Servers/PDomains/PDomain_n/HOST/tpm
Table 77 TPM Property Values for Legacy Host SPARC Servers
TPM
(enable=)
(activate=)
(forceclear=)
Disabled ('false')
Enable=false | true;
Forceclear=false | true;
Activate=false | true
To enable the SPARC server TPM device on the next host power-on
event, set the properties for Enable and Activate to 'true'.
To purge all TPM device data on the SPARC server, set the property
for Enable to 'false' and set the property for Forceclear to 'true'.
Note -
Properties:
set HOST/tpm
enable=[true|false]
activate=[true|false]
