Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x
Exit Print View
Updated: November 2019
Reset Factory Defaults for SP and Oracle ILOM BIOS
Before You Begin
Follow these steps to reset the Oracle ILOM configuration and the host BIOS configuration to factory defaults from the Oracle ILOM CLI or web interface.
  1. Power off the host operating system on the managed Oracle x86 server by performing one of the following:
    • From the web interface, click Host Management > Power Control > Power Cycle.
    • From the CLI, type: stop -force /System
  2. Reset the parameters in BIOS non-volatile data store to factory defaults by performing one of the following:
    • From the web interface, click System Management > BIOS, then select Factory from the Reset Defaults To Factory list box, and click Save.
    • From the CLI, type: set /System/BIOS reset_to_defaults=factory
    Note -  Wait until /System/BIOS reset_to_defaults changes from factory to none before proceeding with Step 3. The reset_to_defaults value reverts back to none after the factory defaults have been applied to the host BIOS non-volatile data store.
  3. Reset the Oracle ILOM configuration to factory defaults by performing one of the following:
    • From the web interface, click ILOM Administration> Configuration Management > Reset Defaults, then select Factory from the Reset Defaults list box, and click Reset Defaults.
    • From the CLI, type: set /SP reset_to_defaults=factory
  4. Power cycle the Oracle ILOM SP by performing one of the following:
    • From the web interface, click Host Management > Power Control > Reset.
    • From the CLI, type: reset /SP
    Oracle ILOM resets BIOS configuration parameters to factory defaults and returns None as the Sync Status state.
Related Information:
