Before You Begin
Review the Requirements for BIOS Configuration Tasks.
From the web interface, click System Management > BIOS, then select Factory from the Reset To Defaults list box and click Save.
From the CLI, type: set /System/BIOS reset_to_defaults=factory
Oracle ILOM resets the BIOS Setup parameters in the non-volatile data store to factory defaults. The Reset To Defaults value reverts to None after the factory default parameters are applied.
