Perform the following procedure to optionally modify the default network port 2121 used by Oracle ILOM for storage redirection.
Before You Begin
The following procedure requires access to the Jnlpgenerator-cli file.
The Console (c) role is required to run the storage redirection service from the Oracle ILOM web interface.
After modifying the default storage redirection port number, Oracle ILOM storage redirection users must always specify the non-default port number when starting, stopping, or viewing storage redirections from the command window or terminal.
To modify the default storage redirection network port 2121, follow these steps:
Open the locally stored Jnlpgenerator-cli file using a text editor.
The Opening Jnlpgenerator-cli file dialog box appears.
File example:
<application-desc> <argument>cli</argument> <argument>2121</argument> </application-desc>
After changing the default network port 2121 and saving the changes to the locally stored Jnlpgenerator-cli file, the non-default port number must always be specified when starting, stopping, or viewing storage redirections from the command window or terminal.
