The switch ships with DHCP IP address assignment for the SP.
-> set /SP/network property=value property=value ...
where:
property is the parameter of the network to configure.
value is the value of the property to configure.
These properties are supported:
pendingipaddress – value is the IP address of the SP to be configured.
pendingipdiscovery – value is the method of IP discovery to be configured, either static or dhcp.
pendingipgateway – value is the IP address of the routing gateway to be configured.
pendingipnetmask – value is the netmask to be configured.
For example:
-> set /SP/network pendingipdiscovery=static pendingipaddress=123.45.67.89 pendingipgateway=123.45.67.1 pendingipnetmask=255.255.255.0 Set 'pendingipdiscovery' to 'static' Set 'pendingipaddress' to '123.45.67.89' Set 'pendingipgateway' to '123.45.67.1' Set 'pendingipnetmask' to '255.255.255.0' ->
-> set /SP/network commitpending=true Set 'commitpending' to 'true' ->
The static IP address has been configured to 123.45.67.89. You can now manage the SP from any one of the RJ-45 connectors on the rear panel.
