![]() | Caution - Running the Oracle Fabric OS configuration wizard destroys data. If you are manually running the wizard, consider backing up configuration data before proceeding. |
[OFOS} system clear config This is a destructive operation. Your configuration will be cleared and the system will be restarted. Please type 'confirm' to clear the configuration and restart the system. > confirm
Type Y.
When completed, the wizard reboots Oracle Fabric OS.
