Cable Precautions
To prevent data cable damage, you must follow these
cautions.
Do not uncoil the cable, as a kink might occur. Hold the coil
closed as you unroll the cable, pausing to allow the cable to relax
as it is unrolled.
Do not step on the cable or connectors. Plan cable paths away from
foot traffic or rolling loads.
Do not pull the cable out of the shipping box, through any
opening, or around any corners. Unroll the cable as you lay it down
and move it through turns.
Do not bend the cables to a radius tighter than 85 mm (3.4
inches). Ensure that cable turns are as wide as possible.
Do not twist the cable to open a kink. If it is not severe, open
the kink by unlooping the cable.
Do not pack the cable to fit a tight space. Use an alternative
cable route.
Do not straighten the cable to correct a bend that is too tight.
Leave the cable bend as is.
Do not hang the cable for a length more than 2 meters (7 feet).
Minimize the hanging weight with intermediate retention
points.
Do not drop the cable or connectors from any height. Gently set
the cable down, resting the cable connectors on a stable
surface.
Do not cinch the cable with hard fasteners or cable ties. Use soft
hook-and-loop fastener for bundling and securing cables.
Do not drag the cable or its connectors over any surface. Carry
the entire cable to and from the points of connection.
Do not force the cable connector into the receptacle by pushing on
the cable. Apply connection or disconnection forces at the connector
only.
