Assemble the SFP+ Cables
If the optical SFP+ cables are unassembled, you must assemble the cables before
attaching them to the switch.
Note -
The ends of the optical fiber cable and the receptacles of the transceivers
must be clean and optically clear before assembly. Do not remove the protective
caps from the optical fiber cable or the plugs from the transceivers until
instructed to do so.
Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
Remove the SFP+ optical transceivers and fiber optic cables from their
packaging.
Remove the plug from an SFP+ optical transceiver.
Remove the caps from an LC connector of the fiber optic cable.
Holding the shafts of the LC connector, insert the LC connector into the
receptacles of the SFP+ optical transceiver.
Note -
The LC connector and SFP+ receptacles are keyed for proper fitting.
Push the connector into the transceiver until it clicks.
Repeat from Step 3 for the other end of the cable.
Repeat from Step 2 for all SFP+ cables to be assembled.
Route the data cables.
See Route the Cables.
