周囲温度
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:11:35 2015 System MB (Motherboard) fault.chassis.env.temp.over-fail (Probability:100, UUID:4c4bdfa1-f7d5-c7a7-e59e-f9a8ce4fab21, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
バッテリ
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:00:01 2015 System MB (Motherboard) fault.chassis.battery.fail (Probability:100, UUID:76a2179a-51bd-c836-a7f1-af62953577fa, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
ファンモジュール
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:18:44 2015 System FMx (Fan Module) fault.chassis.device.fan.fail (Probability:100, UUID:0ebf1655-8700-c90e-fa53-ea6c3b2b25a0, Resource:/SYS/FMx, Part Number:N/A, Serial Number:N/A, Reference Document:http://support.oracle.com/msg/---)
メインボードの温度
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:04:16 2015 System MB (Motherboard) fault.chassis.temp.shutdown (Probability:50, UUID:01bacc0f-986e-e346-94aa-84e41a1c1595, Resource:/SYS/MB, Part Number:7092577, Serial Number:BS00329231, Reference Document:http://support.oracle.com/msg/---)
メインボードの電圧
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:13:26 2015 System SP (Service Processor) fault.chassis.voltage.fail (Probability:100, UUID:0a408985-6011-ccd7-c3a1-e01c7254ea87, Resource:/SYS/SP, Part Number:7096151, Serial Number:BS9089M+15306P00M0, Reference Document:http://support.oracle.com/msg/---)
電源装置
Date/Time Subsystems Component ------------------------ ------------------ ------------ Thu Dec 17 05:17:11 2015 Power PSx (Power Supply 1) fault.chassis.device.psu.fail (Probability:100, UUID:b516a939-23c2-ee8b-e997-d915ca03d044, Resource:/SYS/PSx, Part Number:7065505-01, Serial Number:BS2517, Reference Document:http://support.oracle.com/msg/---)
