man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
audio_engine_get_private(9F)
Name
audio_engine_set_private, audio_engine_get_private - set or get private state for an audio engine
Synopsis
#include <sys/audio/audio_driver.h>
void *audio_engine_get_private(audio_engine_t *eng);
void audio_engine_set_private(audio_engine_t *eng, void *state)
Parameters
eng
pointer to an audio engine allocated with audio_engine_alloc(9F)
state
a private soft state structure for the device driver
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_engine_set_private() function stores a pointer to the driver private state for the engine in the audio engine structure.
The pointer to the private state established by audio_engine_set_private() is passed as the first argument to the engine's entry points registered in the audio_engine_ops (9S) structure.
The audio_engine_get_private() function retrieves the previously stored private state pointer.
Return Values
The audio_engine_get_private() function returns the device driver private state pointer.
Context
These functions may be called from any context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
attributes(5), audio(7D) , audio_engine_alloc(9F), audio_engine_ops (9S)
