man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
scsi_sense_key(9F)
Name
scsi_sense_key, scsi_sense_asc, scsi_sense_ascq - retrieve fields from SCSI sense data
Synopsis
#include <sys/scsi/scsi.h>
uint8_t scsi_sense_key(uint8_t *sense_buffer);
uint8_t scsi_sense_asc(uint8_t *sense_buffer);
uint8_t scsi_sense_ascq(uint8_t *sense_buffer);
Interface Level
Solaris DDI specific (Solaris DDI).
Parameters
sense_buffer
Pointer to a buffer containing SCSI sense data. The sense data is expected in wire format starting at the response code. It can be in either fixed or descriptor format.
Description
The scsi_sense_key() function returns the sense key value from the sense data contained in the sense_buffer.
The scsi_sense_asc() function returns the additional sense code (ASC) value from the sense data contained in the sense_buffer.
The scsi_sense_ascq() function returns the additional sense code qualifier (ASCQ) value from the sense data contained in the sense_buffer.
The scsi_sense_key(), scsi_sense_asc(), and scsi_sense_ascq() functions are used to retrieve values from SCSI sense data, regardles of whether the sense data is in fixed format or descriptor format.
Drivers should use scsi_validate_sense(9F) to ensure that valid sense key, asc, and ascq values are present in the sense data.
Return Values
The scsi_sense_key() function returns the sense key value from the sense buffer. The scsi_sense_asc() function returns the additional sense code (ASC) from the sense buffer and the scsi_sense_ascq() function returns the additional sense code qualifier (ASCQ) from the sense buffer.
Context
The scsi_sense_key(), scsi_sense_asc(), and scsi_sense_ascq() functions can be called from user or interrupt context.
See Also
scsi_ext_sense_fields(9F), scsi_find_sense_descr(9F), scsi_sense_cmdspecific_uint64(9F), scsi_sense_info_uint64(9F), scsi_validate_sense(9F)
