#include <sys/ddi.h> #include <sys/sunddi.h> uint_t ddi_mmap_get_model(void);
Solaris DDI specific (Solaris DDI).
ddi_mmap_get_model() returns the C Language Type Model which the current thread expects. ddi_mmap_get_model() is used in combination with ddi_model_convert_from(9F) in the mmap(9E) driver entry point to determine whether there is a data model mismatch between the current thread and the device driver. The device driver might have to adjust the shape of data structures before exporting them to a user thread which supports a different data model.
Current thread expects 32-bit (ILP32) semantics.
Current thread expects 64-bit (LP64) semantics.
The ddi_mmap_get_model() function was not called from the mmap(9E) entry point.
The ddi_mmap_get_model() function can only be called from the mmap(9E) driver entry point.
The following is an example of the mmap( 9E) entry point and how to support 32-bit and 64-bit applications with the same device driver.
struct data32 { int len; caddr32_t addr; }; struct data { int len; caddr_t addr; }; xxmmap(dev_t dev, off_t off, int prot) { struct data dtc; /* a local copy for clash resolution */ struct data *dp = (struct data *)shared_area; switch (ddi_model_convert_from(ddi_mmap_get_model())) { case DDI_MODEL_ILP32: { struct data32 *da32p; da32p = (struct data32 *)shared_area; dp = &dtc; dp->len = da32p->len; dp->address = da32->address; break; } case DDI_MODEL_NONE: break; } /* continues along using dp */ … }
