man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
pm_busy_component(9F)
Name
pm_busy_component, pm_idle_component - control device component availability for Power Management
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
int pm_busy_component(dev_info_t *dip, int component);
int pm_idle_component(dev_info_t *dip, int component);
Interface Level
Solaris DDI specific (Solaris DDI)
Parameters
dip
Pointer to the device's dev_info structure.
component
The number of the component to be power-managed.
Description
The pm_busy_component() function sets component of dip to be busy. Calls to pm_busy_component() are stacked, requiring a corresponding number of calls to pm_idle_component() to make the component idle again. When a device is busy it will not be power-managed by the system.
The pm_idle_component() function marks component idle, recording the time that component went idle. This function must be called once for each call to pm_busy_component(). A component which is idle is available to be power-managed by the system. The pm_idle_component() function has no effect if the component is already idle, except to update the system's notion of when the device went idle.
If these functions are called as a result of entry into the driver's attach(9E), detach(9E) or power(9E) entry point, these functions must be called from the same thread which entered attach(9E), detach(9E) or power(9E).
Return Values
The pm_busy_component() and pm_idle_component() functions return:
DDI_SUCCESS
Successfully set the indicated component busy or idle.
DDI_FAILURE
Invalid component number component or the device has no components.
Context
These functions can be called from user or kernel context. These functions may also be called from interrupt context, providing they are not the first Power Management function called by the driver.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See also
pm(7D), attach(9E), detach(9E), power(9E), pm_raise_power(9F), pm(9P), pm-components(9P)
Writing Device Drivers for Oracle Solaris 11.2
