man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
Name
csx_Parse_CISTPL_CFTABLE_ENTRY - parse 16-bit Card Configuration Table Entry tuple
Synopsis
#include <sys/pccard.h>
int32_t csx_Parse_CISTPL_CFTABLE_ENTRY(client_handle_t ch, tuple_t *tu,
     cistpl_cftable_entry_t *cft);
Interface Level
Solaris DDI Specific (Solaris DDI)
Parameters
ch
Client handle returned from csx_RegisterClient(9F).
tu
Pointer to a tuple_t structure (see tuple(9S)) returned by a call to csx_GetFirstTuple(9F) or csx_GetNextTuple(9F).
cft
Pointer to a cistpl_cftable_entry_t structure which contains the parsed CISTPL_CFTABLE_ENTRY tuple information upon return from this function.
Description
This function parses the 16 bit Card Configuration Table Entry tuple, CISTPL_CFTABLE_ENTRY, into a form usable by PC Card drivers.
The CISTPL_CFTABLE_ENTRY tuple is used to describe each possible configuration of a PC Card and to distinguish among the permitted configurations. The CISTPL_CONFIG tuple must precede all CISTPL_CFTABLE_ENTRY tuples.
Structure Members
The structure members of cistpl_cftable_entry_t are:
uint32_t                      flags;     /* valid descriptions */
uint32_t                      ifc;       /* interface description */
                                         /*	information */
uint32_t                      pin;       /* values for PRR */
uint32_t                      index;     /* configuration index number */
cistpl_cftable_entry_pd_t     pd;        /* power requirements */
                                         /* description */
cistpl_cftable_entry_speed_t  speed;     /* device speed description */
cistpl_cftable_entry_io_t     io;        /* device I/O map */
cistpl_cftable_entry_irq_t    irq;       /* device IRQ utilization */
cistpl_cftable_entry_mem_t    mem;       /* device memory space */
cistpl_cftable_entry_misc_t   misc;      /* miscellaneous
                                         /* device features */
The flags field is defined and bit-mapped as follows:
CISTPL_CFTABLE_TPCE_DEFAULT
This is a default configuration
CISTPL_CFTABLE_TPCE_IF
If configuration byte exists
CISTPL_CFTABLE_TPCE_FS_PWR
Power information exists
CISTPL_CFTABLE_TPCE_FS_TD
Timing information exists
CISTPL_CFTABLE_TPCE_FS_IO
I/O information exists
CISTPL_CFTABLE_TPCE_FS_IRQ
IRQ information exists
CISTPL_CFTABLE_TPCE_FS_MEM
MEM space information exists
CISTPL_CFTABLE_TPCE_FS_MISC
MISC information exists
CISTPL_CFTABLE_TPCE_FS_STCE_EV
STCE_EV exists
CISTPL_CFTABLE_TPCE_FS_STCE_PD
STCE_PD exists
If the CISTPL_CFTABLE_TPCE_IF flag is set, the ifc field is bit-mapped and defined as follows:
CISTPL_CFTABLE_TPCE_IF_MEMORY
Memory interface
CISTPL_CFTABLE_TPCE_IF_IO_MEM
IO and memory
CISTPL_CFTABLE_TPCE_IF_CUSTOM_0
Custom interface 0
CISTPL_CFTABLE_TPCE_IF_CUSTOM_1
Custom interface 1
CISTPL_CFTABLE_TPCE_IF_CUSTOM_2
Custom interface 2
CISTPL_CFTABLE_TPCE_IF_CUSTOM_3
Custom interface 3
CISTPL_CFTABLE_TPCE_IF_MASK
Interface type mask
CISTPL_CFTABLE_TPCE_IF_BVD
BVD active in PRR
CISTPL_CFTABLE_TPCE_IF_WP
WP active in PRR
CISTPL_CFTABLE_TPCE_IF_RDY
RDY active in PRR
CISTPL_CFTABLE_TPCE_IF_MWAIT
WAIT - mem cycles
pin is a value for the Pin Replacement Register.
index is a configuration index number.
The structure members of cistpl_cftable_entry_pd_t are:
uint32_t                    flags;     /* which descriptions are valid */
cistpl_cftable_entry_pwr_t  pd_vcc;    /* VCC power description */
cistpl_cftable_entry_pwr_t  pd_vpp1;   /* Vpp1 power description */
cistpl_cftable_entry_pwr_t  pd_vpp2;   /* Vpp2 power description */
This flags field is bit-mapped and defined as follows:
CISTPL_CFTABLE_TPCE_FS_PWR_VCC
Vcc description valid
CISTPL_CFTABLE_TPCE_FS_PWR_VPP1
Vpp1 description valid
CISTPL_CFTABLE_TPCE_FS_PWR_VPP2
Vpp2 description valid
The structure members of cistpl_cftable_entry_pwr_t are:
uint32_t     nomV;        /* nominal supply voltage */
uint32_t     nomV_flags;
uint32_t     minV;        /* minimum supply voltage */
uint32_t     minV_flags;
uint32_t     maxV;        /* maximum supply voltage */
uint32_t     maxV_flags;
uint32_t     staticI;     /* continuous supply current */
uint32_t     staticI_flags;
uint32_t     avgI;        /* max current required averaged over 1 sec. */
uint32_t     avgI_flags;
uint32_t     peakI;       /* max current required averaged over 10mS */
uint32_t     peakI_flags;
uint32_t     pdownI;      /* power down supply current required */
uint32_t     pdownI_flags;
nomV, minV, maxV, staticI, avgI, peakI_flag, and pdownI are defined and bit-mapped as follows:
CISTPL_CFTABLE_PD_NOMV
Nominal supply voltage
CISTPL_CFTABLE_PD_MINV
Minimum supply voltage
CISTPL_CFTABLE_PD_MAXV
Maximum supply voltage
CISTPL_CFTABLE_PD_STATICI
Continuous supply current
CISTPL_CFTABLE_PD_AVGI
Maximum current required averaged over 1 second
CISTPL_CFTABLE_PD_PEAKI
Maximum current required averaged over 10mS
CISTPL_CFTABLE_PD_PDOWNI
Power down supply current required
nomV_flags, minV_flags, maxV_flags, staticI_flags, avgI_flags, peakI_flags, and pdownI_flags are defined and bit-mapped as follows:
CISTPL_CFTABLE_PD_EXISTS
This parameter exists
CISTPL_CFTABLE_PD_MUL10
Multiply return value by 10
CISTPL_CFTABLE_PD_NC_SLEEP
No connection on sleep/power down
CISTPL_CFTABLE_PD_ZERO
Zero value required
No connection ever
The structure members of cistpl_cftable_entry_speed_t are:
uint32_t    flags;       /* which timing information is present */
uint32_t    wait;        /* max WAIT time in device speed format */
uint32_t    nS_wait;     /* max WAIT time in nS */
uint32_t    rdybsy;      /* max RDY/BSY time in device speed format */
uint32_t    nS_rdybsy;   /* max RDY/BSY time in nS */
uint32_t    rsvd;        /* max RSVD time in device speed format */
uint32_t    nS_rsvd;     /* max RSVD time in nS */
The flags field is bit-mapped and defined as follows:
CISTPL_CFTABLE_TPCE_FS_TD_WAIT
WAIT timing exists
CISTPL_CFTABLE_TPCE_FS_TD_RDY
RDY/BSY timing exists
CISTPL_CFTABLE_TPCE_FS_TD_RSVD
RSVD timing exists
The structure members of cistpl_cftable_entry_io_t are:
uint32_t     flags;        /* direct copy of TPCE_IO byte in tuple */
uint32_t     addr_lines;   /* number of decoded I/O address lines */
uint32_t     ranges;       /* number of I/O ranges */
cistpl_cftable_entry_io_range_t
              range[CISTPL_CFTABLE_ENTRY_MAX_IO_RANGES];
CISTPL_CFTABLE_TPCE_FS_IO_BUS
Bus width mask
CISTPL_CFTABLE_TPCE_FS_IO_BUS8
8-bit flag
CISTPL_CFTABLE_TPCE_FS_IO_BUS16
16-bit flag
CISTPL_CFTABLE_TPCE_FS_IO_RANGE
IO address ranges exist
The structure members of cistpl_cftable_entry_io_range_t are:
uint32_t     addr;     /* I/O start address */
uint32_t     length;   /* I/O register length */
The structure members of cistpl_cftable_entry_irq_t are:
uint32_t     flags;   /* direct copy of TPCE_IR byte in tuple */
uint32_t     irqs;    /* bit mask for each allowed IRQ */
The structure members of cistpl_cftable_entry_mem_t are:
uint32_t     flags;     /* memory descriptor type and host addr info */
uint32_t     windows;   /* number of memory space descriptors */
cistpl_cftable_entry_mem_window_t
         window[CISTPL_CFTABLE_ENTRY_MAX_MEM_WINDOWS];
CISTPL_CFTABLE_TPCE_FS_MEM3
Space descriptors
CISTPL_CFTABLE_TPCE_FS_MEM2
host_addr=card_addr
CISTPL_CFTABLE_TPCE_FS_MEM1
Card address=0 any host address
CISTPL_CFTABLE_TPCE_FS_MEM_HOST
If host address is present in MEM3
The structure members of cistpl_cftable_entry_mem_window_t are:
uint32_t     length;     /* length of this window */
uint32_t     card_addr;  /* card address */
uint32_t     host_addr;  /* host address */
The structure members of cistpl_cftable_entry_misc_t are:
uint32_t     flags;      /* miscellaneous features flags */
CISTPL_CFTABLE_TPCE_MI_MTC_MASK
Max twin cards mask
CISTPL_CFTABLE_TPCE_MI_AUDIO
Audio on BVD2
CISTPL_CFTABLE_TPCE_MI_READONLY
R/O storage
CISTPL_CFTABLE_TPCE_MI_PWRDOWN
Powerdown capable
CISTPL_CFTABLE_TPCE_MI_DRQ_MASK
DMAREQ mask
CISTPL_CFTABLE_TPCE_MI_DRQ_SPK
DMAREQ on SPKR
CISTPL_CFTABLE_TPCE_MI_DRQ_IOIS
DMAREQ on IOIS16
CISTPL_CFTABLE_TPCE_MI_DRQ_INP
DMAREQ on INPACK
CISTPL_CFTABLE_TPCE_MI_DMA_8
DMA width 8 bits
CISTPL_CFTABLE_TPCE_MI_DMA_16
DMA width 16 bits
Return Values
CS_SUCCESS
Successful operation.
CS_BAD_HANDLE
Client handle is invalid.
CS_UNKNOWN_TUPLE
Parser does not know how to parse tuple.
CS_NO_CARD
No PC Card in socket.
CS_NO_CIS
No Card Information Structure (CIS) on PC Card.
CS_UNSUPPORTED_FUNCTION
No PCMCIA hardware installed.
Context
This function may be called from user or kernel context.
See Also
csx_GetFirstTuple(9F), csx_GetTupleData(9F), csx_Parse_CISTPL_CONFIG(9F), csx_RegisterClient(9F), csx_ValidateCIS(9F), tuple(9S)
PC Card 95 Standard, PCMCIA/JEIDA
