#include <sys/pccard.h> int32_t csx_Parse_CISTPL_VERS_1(client_handle_t ch, tuple_t *tu, cistpl_vers_1_t *cv1);
Solaris DDI Specific (Solaris DDI)
Client handle returned from csx_RegisterClient(9F).
Pointer to a tuple_t structure (see tuple(9S)) returned by a call to csx_GetFirstTuple(9F) or csx_GetNextTuple(9F).
Pointer to a cistpl_vers_1_t structure which contains the parsed CISTPL_VERS_1 tuple information upon return from this function.
This function parses the Level-1 Version/Product Information tuple, CISTPL_VERS_1, into a form usable by PC Card drivers.
The CISTPL_VERS_1 tuple is used to describe the card Level-1 version compliance and card manufacturer information.
The structure members of cistpl_vers_1_t are:
uint32_t major; /* major version number */ uint32_t minor; /* minor version number */ uint32_t ns; /* number of information strings */ char pi[CISTPL_VERS_1_MAX_PROD_STRINGS] [CIS_MAX_TUPLE_DATA_LEN]; /* pointers to product information strings */
Successful operation.
Client handle is invalid.
Parser does not know how to parse tuple.
No PC Card in socket.
No Card Information Structure (CIS) on PC Card.
No PCMCIA hardware installed.
This function may be called from user or kernel context.
csx_GetFirstTuple(9F), csx_GetTupleData(9F), csx_RegisterClient(9F), csx_ValidateCIS(9F), tuple(9S)
PC Card 95 Standard, PCMCIA/JEIDA
