man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_rep_getll(9F)
Name
ddi_rep_get8, ddi_rep_get16, ddi_rep_get32, ddi_rep_get64, ddi_rep_getw, ddi_rep_getl, ddi_rep_getll, ddi_rep_getb - read data from the mapped memory address, device register or allocated DMA memory address
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
void ddi_rep_get8(ddi_acc_handle_t handle, uint8_t *host_addr,
     uint8_t *dev_addr, size_t repcount, uint_t flags);
void ddi_rep_get16(ddi_acc_handle_t handle, uint16_t *host_addr,
     uint16_t *dev_addr, size_t repcount, uint_t flags);
void ddi_rep_get32(ddi_acc_handle_t handle, uint32_t *host_addr,
     uint32_t *dev_addr, size_t repcount, uint_t flags);
void ddi_rep_get64(ddi_acc_handle_t handle, uint64_t *host_addr,
     uint64_t *dev_addr, size_t repcount, uint_t flags);
Interface Level
Solaris DDI specific (Solaris DDI). The ddi_rep_getb(), ddi_rep_getl(), ddi_rep_getll(), and ddi_rep_getw() functions are obsolete. The ddi_rep_get8() function replaces ddi_rep_getb(). The ddi_rep_get32() function replaces ddi_rep_getl(). The ddi_rep_get64() function replaces ddi_rep_getll(). The ddi_rep_get16() function replaces ddi_rep_getw().
Parameters
handle
The data access handle returned from setup calls, such as ddi_regs_map_setup(9F).
host_addr
Base host address.
dev_addr
Base device address.
repcount
Number of data accesses to perform.
flags
Device address flags:
DDI_DEV_AUTOINCR
Automatically increment the device address, dev_addr, during data accesses.
DDI_DEV_NO_AUTOINCR
Do not advance the device address, dev_addr, during data accesses.
Description
These routines generate multiple reads from the mapped memory or device register. repcount data is copied from the device address, dev_addr, to the host address, host_addr. For each input datum, the ddi_rep_get8 (), ddi_rep_get16(), ddi_rep_get32(), and ddi_rep_get64() functions read 8 bits, 16 bits, 32 bits, and 64 bits of data, respectively, from the device address, dev_addr. dev_addr and host_addr must be aligned to the datum boundary described by the function.
Each individual datum will automatically be translated to maintain a consistent view between the host and the device based on the encoded information in the data access handle. The translation may involve byte-swapping if the host and the device have incompatible endian characteristics.
When the flags argument is set to DDI_DEV_AUTOINCR, these function treat the device address, dev_addr, as a memory buffer location on the device and increment its address on the next input datum. However, when the flags argument is to DDI_DEV_NO_AUTOINCR, the same device address will be used for every datum access. For example, this flag may be useful when reading from a data register.
Return Values
These functions return the value read from the mapped address.
Context
These functions can be called from user, kernel, or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
ddi_rep_getb(), ddi_rep_getl(), ddi_rep_getll(), and ddi_rep_getw() are Obsolete
ddi_rep_get8(), ddi_rep_get16(), ddi_rep_get32(), ddi_rep_get64() are Committed
See Also
ddi_get8(9F), ddi_put8(9F), ddi_regs_map_free(9F), ddi_regs_map_setup(9F), ddi_rep_put8(9F)
