man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
usb_pipe_ctrl_xfer(9F)
Name
usb_pipe_ctrl_xfer, usb_pipe_ctrl_xfer_wait - USB control pipe transfer functions
Synopsis
#include <sys/usb/usba.h>
int usb_pipe_ctrl_xfer(usb_pipe_handle_t pipe_handle,
     usb_ctrl_req_t *request, usb_flags_t flags);
int usb_pipe_ctrl_xfer_wait(usb_pipe_handle_t pipe_handle,
     usb_ctrl_setup_t *setup, mblk_t **data,
     usb_cr_t * completion_reason, usb_cb_flags_t *cb_flags,
     usb_flags_t flags);
Interface Level
Solaris DDI specific (Solaris DDI)
Parameters
For usb_pipe_ctrl_xfer():
pipe_handle
Control pipe handle on which request is made.
request
Pointer to control transfer request.
flags
USB_FLAGS_SLEEP is the only flag recognized. Wait for all pending request callbacks to complete.
For usb_pipe_ctrl_xfer_wait():
pipe_handle
setup
Pointer to setup parameters. (See below.)
data
Pointer to mblk containing data bytes to transfer with command. Ignored if NULL.
completion_reason
Returns overall completion status. Ignored if NULL. Please see usb_callback_flags(9S) for more information.
callback_flags
Returns flags set either during autoclearing or some other callback, which indicate recovery handling done in callback. Ignored if NULL.
flags
No flags are recognized. Reserved for future expansion.
Description
The usb_pipe_ctrl_xfer() function requests the USBA framework to perform a transfer through a USB control pipe. The request is passed to the host controller driver (HCD), which performs the necessary transactions to complete the request. Requests are synchronous when USB_FLAGS_SLEEP is specified in flags; calls for synchronous requests do not return until their transaction is completed. Asynchronous requests (made without specifying the USB_FLAGS_SLEEP flag) notifies the caller of their completion via a callback function.
The usb_pipe_ctrl_xfer_wait() function is a wrapper around usb_pipe_ctrl_xfer() that performs allocation and deallocation of all required data structures, and a synchronous control-pipe transfer. It takes a usb_ctrl_setup_t containing most usb setup parameters as an argument:
 uchar_t      bmRequestType   /* characteristics of request. */
                              /* (See USB 2.0 spec, section 9.3). */
                              /*  Combine one direction of:   */
                              /*      USB_DEV_REQ_HOST_TO_DEV */
                              /*      USB_DEV_REQ_DEV_TO_HOST */
                              /*  with one request type of:   */
                              /*      USB_DEV_REQ_TYPE_STANDARD */
                              /*      USB_DEV_REQ_TYPE_CLASS  */
                              /*      USB_DEV_REQ_TYPE_VENDOR */
                              /*  with one recipient type of: */
                              /*      USB_DEV_REQ_RCPT_DEV    */
                              /*      USB_DEV_REQ_RCPT_IF     */
                              /*      USB_DEV_REQ_RCPT_EP     */
                              /*      USB_DEV_REQ_RCPT_OTHER. */
 uchar_t      bRequest        /* request or command.          */
                              /* (See USB 2.0 spec, section   */
                              /* 9.3 for standard commands.)  */
 uint16_t     wValue         /* value which varies according to */
                              /* the command (bRequest).      */
 uint16_t     wIndex          /* value which varies according to */
                              /* the command, typically used to */
                              /* pass an index or offset. */
 uint16_t     wLength         /* number of data bytes to transfer */
                              /* with command, if any.  Same as */
                              /* size of mblk "data" below.   */
 usb_req_attrs_t attrs;       /* required request attributes */
Please see usb_request_attributes(9S), or refer to Section 5.5 of the USB 2.0 specification for more information on these parameters. (The USB 2.0 specification is available at www.usb.org.)
Mblks for data are allocated optionally when a request is allocated via usb_alloc_ctrl_req(9F) by passing a positive value for the len argument. Control requests passing or receiving no supplemental data need not allocate an mblk.
Return Values
USB_SUCCESS
Transfer was successful.
USB_INVALID_ARGS
Request is NULL.
USB_INVALID_CONTEXT
Called from interrupt context with the USB_FLAGS_SLEEP flag set.
USB_INVALID_REQUEST
The request has been freed or otherwise invalidated.
A set of conflicting attributes were specified. See usb_request_attributes(9S).
The normal and/or exception callback is NULL and USB_FLAGS_SLEEP is not set.
Data space not provided to a control request while ctrl_wLength is nonzero.
USB_INVALID_PIPE
Pipe handle is NULL or invalid.
Pipe is closing or closed.
USB_NO_RESOURCES
Memory, descriptors or other resources unavailable.
USB_HC_HARDWARE_ERROR
Host controller is in error state.
USB_FAILURE
An asynchronous transfer failed or an internal error occurred.
The pipe is in an unsuitable state (error, busy, not ready).
Additional status information may be available in the ctrl_completion_reason and ctrl_cb_flags fields of the request. Please see usb_callback_flags(9S) and usb_completion_reason(9S) for more information.
USB_SUCCESS
Request was successful.
USB_INVALID_CONTEXT
Called from interrupt context.
USB_INVALID_ARGS
dip is NULL.
Any error code returned by usb_pipe_ctrl_xfer().
Context
The usb_pipe_ctrl_xfer() function may be called from kernel or user context without regard to arguments and from the interrupt context only when the USB_FLAGS_SLEEP flag is clear.
The usb_pipe_ctrl_xfer_wait() function may be called from kernel or user context.
Examples
  /* Allocate, initialize and issue a synchronous control request. */
  usb_ctrl_req_t ctrl_req;
  void control_pipe_exception_callback(
      usb_pipe_handle_t, usb_ctrl_req_t*);
  ctrl_req = usb_alloc_ctrl_req(dip, 0, USB_FLAGS_SLEEP);
  ctrl_req->ctrl_bmRequestType = USB_DEV_REQ_HOST_TO_DEV |
      USB_DEV_REQ_TYPE_CLASS | USB_DEV_REQ_RCPT_OTHER;
  ctrl_req->ctrl_bRequest     = (uint8_t)USB_PRINTER_SOFT_RESET;
  ctrl_req->ctrl_exc_cb       = control_pipe_exception_callback;
  if ((rval = usb_pipe_ctrl_xfer(pipe, ctrl_req, USB_FLAGS_SLEEP))
      != USB_SUCCESS) {
          cmn_err (CE_WARN, "%s%d: Error issuing USB cmd.",
              ddi_driver_name(dip), ddi_get_instance(dip));
   * Allocate, initialize and issue an asynchronous control request to
   * read a configuration descriptor.
  usb_ctrl_req_t *ctrl_req;
  void control_pipe_normal_callback(
  struct buf *bp = ...;
  ctrl_req =
      usb_alloc_ctrl_req(dip, sizeof(usb_cfg_descr_t), USB_FLAGS_SLEEP);
  ctrl_req->ctrl_bmRequestType = USB_DEV_REQ_DEV_TO_HOST |
      USB_DEV_REQ_TYPE_STANDARD | USB_DEV_REQ_RCPT_DEV;
  ctrl_req->ctrl_wLength      = sizeof(usb_cfg_descr_t);
  ctrl_req->ctrl_wValue       = USB_DESCR_TYPE_SETUP_CFG | 0;
  ctrl_req->ctrl_bRequest     = (uint8_t)USB_REQ_GET_DESCR;
  ctrl_req->ctrl_cb           = control_pipe_normal_callback;
  /* Make buf struct available to callback handler. */
  ctrl_req->ctrl_client_private = (usb_opaque_t)bp;
  if ((rval = usb_pipe_ctrl_xfer(pipe, ctrl_req, USB_FLAGS_NOSLEEP))
      != USB_SUCCESS) {
  /* Call usb_pipe_ctrl_xfer_wait() to get device status. */
  mblk_t *data;
  usb_cr_t completion_reason;
  usb_cb_flags_t callback_flags;
  usb_ctrl_setup_t setup_params = {
      USB_DEV_REQ_DEV_TO_HOST |       /* bmRequestType */
          USB_DEV_REQ_TYPE_STANDARD | USB_DEV_REQ_RCPT_DEV,
      USB_REQ_GET_STATUS,             /* bRequest */
      0,                              /* wValue */
      0,                              /* wIndex */
      USB_GET_STATUS_LEN,             /* wLength */
      0                               /* attributes. */
  if (usb_pipe_ctrl_xfer_wait(
      pipe,
      &setup_params,
      &data,
      &compleetion_reason,
      &callback_flags,
      0) != USB_SUCCESS) {
          cmn_err (CE_WARN,
              "%s%d: USB get status command failed: "
              "reason=%d callback_flags=0x%x",
              ddi_driver_name(dip), ddi_get_instance(dip),
              completion_reason, callback_flags);
          return (EIO);
  /* Check data length.  Should be USB_GET_STATUS_LEN (2 bytes). */
  length_returned = data->b_wptr - data->b_rptr;
  if (length_returned != USB_GET_STATUS_LEN) {
        cmn_err (CE_WARN,
            "%s%d: USB get status command returned %d bytes of data.",
            ddi_driver_name(dip), ddi_get_instance(dip), length_returned);
          return (EIO);
  /* Retrieve data in endian neutral way. */
  status = (*(data->b_rptr + 1) << 8) | *(data->b_rptr);
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
PCI-based systems
Interface Stability
Committed
Availability
system/io/usb
See also
attributes(5), usb_alloc_request(9F), usb_get_cfg(9F), usb_get_status(9F). usb_pipe_bulk_xfer(9F), usb_pipe_intr_xfer(9F), usb_pipe_isoc_xfer(9F), usb_pipe_open(9F), usb_pipe_reset(9F), usb_pipe_get_state(9F), usb_bulk_request(9S) , usb_callback_flags(9S), usb_ctrl_request(9S), usb_completion_reason(9S), usb_intr_request(9S), usb_isoc_request(9S)
