man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_getll(9F)
Name
ddi_get8, ddi_get16, ddi_get32, ddi_get64, ddi_getb, ddi_getw, ddi_getl, ddi_getll - read data from the mapped memory address, device register or allocated DMA memory address
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
uint8_t ddi_get8(ddi_acc_handle_t handle, uint8_t *dev_addr);
uint16_t ddi_get16(ddi_acc_handle_t handle, uint16_t *dev_addr);
uint32_t ddi_get32(ddi_acc_handle_t handle, uint32_t *dev_addr);
uint64_t ddi_get64(ddi_acc_handle_t handle, uint64_t *dev_addr);
Interface Level
Solaris DDI specific (Solaris DDI). The ddi_getb(), ddi_getl(), ddi_getll(), and ddi_getw() functions are obsolete. The ddi_get8() function replaces ddi_getb(). The ddi_get32 () function replaces ddi_getl(). The ddi_get64() function replaces ddi_getll(). The ddi_get16() function replaces ddi_getw().
Parameters
handle
The data access handle returned from setup calls, such as ddi_regs_map_setup(9F).
dev_addr
Base device address.
Description
The ddi_get8(), ddi_get16(), ddi_get32(), and ddi_get64() functions read 8 bits, 16 bits, 32 bits and 64 bits of data, respectively, from the device address, dev_addr.
Each individual datum will automatically be translated to maintain a consistent view between the host and the device based on the encoded information in the data access handle. The translation may involve byte-swapping if the host and the device have incompatible endian characteristics.
For certain bus types, you can call these DDI functions from a high-interrupt context. These types include ISA and SBus buses. See sysbus (4) and isa (4) for details. For the PCI bus, you can, under certain conditions, call these DDI functions from a high-interrupt context. See pci (4) .
Return Values
These functions return the value read from the mapped address.
Context
These functions can be called from user, kernel, or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
ddi_getb(), ddi_getl(), ddi_getll(), and ddi_getw() are Obsolete;
ddi_get8(), ddi_get16(), ddi_get32(), ddi_get64() are Committed
See Also
ddi_put8(9F), ddi_regs_map_free(9F), ddi_regs_map_setup(9F), ddi_rep_get8(9F), ddi_rep_put8(9F)
